Page 3 of 4
Re: carb seals would they cause running problems
Posted: Sat Jan 28, 2012 2:10 pm
by leerc
all were set to 2.5 except one which was 2.75
all now at 2.25
and got some jubilee clips to secure carbs
Posted: Sun Jan 29, 2012 10:33 am
by leerc
and the throttle cables now snapped feck (new one on route)
on the plus side atleast it never went in a week or 2 and iv have to strip in down again
the carb that was half a turn to far out will explain the fact i had 1 cleanish plug and 3 mingers
Posted: Sun Jan 29, 2012 10:56 am
by leerc
and iv just clicked on its supposed to have 2 throttle cables-i only have the pull,do i really need the push? as the cables completely missing iv got no idea where to route it
thus far the parts iv found to be missing are
exhaust clamp
4 carb clamps
1 throttle cable
1 snorkel
1 rubber flap
and majority of the bellneck seals
the list is likely to be extended by the time u finish this task
Posted: Sun Jan 29, 2012 5:49 pm
by lukemillar
leerc wrote:and iv just clicked on its supposed to have 2 throttle cables-i only have the pull,do i really need the push? as the cables completely missing iv got no idea where to route it
exhaust clamp
4 carb clamps
1 throttle cable
1 snorkel
1 rubber flap
The return cable isn't essential for the bike to run. I don't have one on my NC30. It actually gives a lighter throttle which is nice, but the trade off is a safety one in that you will lose a mechanical means to shut the throttle if the something happens to the carbs (throttle sticks open, something fails etc.)
Posted: Sun Jan 29, 2012 6:09 pm
by leerc
im hoping il have all the bits for tuesday-while its in pieces is it worth adding the 1mm wash to the needles
Posted: Wed Feb 01, 2012 11:00 am
by leerc
got the bellmouths in but still awaiting the throttle cable,hope the carbs seal with jubilee clips
Posted: Wed Feb 01, 2012 5:06 pm
by leerc
all back together now and its alot better but not perfect it still has a slight splutter
the only thing left at this stage is the snorkel (i bought one just awaiting delivery)
Posted: Thu Feb 02, 2012 7:17 pm
by leerc
when i took it out today for a propper test its still there-badly
starts at 5k and goes away at 7
so far
new plugs/filter/oil
carbs clamped in (clamps were missing)-pilots screws set back to stabdard 2.25)
jets/emulsion tubes out cleaned
standard belmouths in
its alot colder today than yesterday but i only took it round the block so never got out of 1st
theres only 2 things left and im not convinced they,ll be helpful-airbox snorkel and the flap under the carb tray
opinions
Posted: Thu Feb 02, 2012 7:59 pm
by Cammo
Both of those parts are critical to how it runs.
Posted: Thu Feb 02, 2012 10:59 pm
by leerc
they were delivered today so ill stick em on tomorrow-it seem alot flatter now higher up im assuming its either the standard bellmouths or the .25 turn in on the pilot screws
if the snorkel/flap resolves the issue im pondering over the idea of turning the pilots out slightly
