carb seals would they cause running problems
Re: carb seals would they cause running problems
all were set to 2.5 except one which was 2.75
all now at 2.25
and got some jubilee clips to secure carbs
all now at 2.25
and the throttle cables now snapped feck (new one on route)
on the plus side atleast it never went in a week or 2 and iv have to strip in down again
the carb that was half a turn to far out will explain the fact i had 1 cleanish plug and 3 mingers
and iv just clicked on its supposed to have 2 throttle cables-i only have the pull,do i really need the push? as the cables completely missing iv got no idea where to route it
thus far the parts iv found to be missing are
exhaust clamp
4 carb clamps
1 throttle cable
1 snorkel
1 rubber flap
and majority of the bellneck seals
the list is likely to be extended by the time u finish this task
exhaust clamp
4 carb clamps
1 throttle cable
1 snorkel
1 rubber flap
The return cable isn't essential for the bike to run. I don't have one on my NC30. It actually gives a lighter throttle which is nice, but the trade off is a safety one in that you will lose a mechanical means to shut the throttle if the something happens to the carbs (throttle sticks open, something fails etc.)leerc wrote:and iv just clicked on its supposed to have 2 throttle cables-i only have the pull,do i really need the push? as the cables completely missing iv got no idea where to route it
exhaust clamp
4 carb clamps
1 throttle cable
1 snorkel
1 rubber flap
im hoping il have all the bits for tuesday-while its in pieces is it worth adding the 1mm wash to the needles
got the bellmouths in but still awaiting the throttle cable,hope the carbs seal with jubilee clips
all back together now and its alot better but not perfect it still has a slight splutter
the only thing left at this stage is the snorkel (i bought one just awaiting delivery)
when i took it out today for a propper test its still there-badly
starts at 5k and goes away at 7
so far
new plugs/filter/oil
carbs clamped in (clamps were missing)-pilots screws set back to stabdard 2.25)
jets/emulsion tubes out cleaned
standard belmouths in
its alot colder today than yesterday but i only took it round the block so never got out of 1st
theres only 2 things left and im not convinced they,ll be helpful-airbox snorkel and the flap under the carb tray
opinions
so far
opinions
Both of those parts are critical to how it runs.
they were delivered today so ill stick em on tomorrow-it seem alot flatter now higher up im assuming its either the standard bellmouths or the .25 turn in on the pilot screws
if the snorkel/flap resolves the issue im pondering over the idea of turning the pilots out slightly
