Re: NC35 Temperature Gauge
Posted: Sat Jul 02, 2011 7:05 am
12v supply to the temp gauge, it earths through the temp sender.
When temps cold, high resistance through sender unit, no needle movement.
When temps hot, low resistance through sender unit, big needle movement.
Go straight to the back of the gauge check supply with multimeter and ring out resistance between gauge and sender unit, my bet is that it's open circuit. Or vibration has shaken a wire free on the back on the gauge.
Either way would recommend you get familiar with a multimeter........ you could of just saved yourself the price of a temp sender! :-)
