lee's nc30 rebuild
leef82
Bike owned: vfr400 nc30
Re: lee's nc30 rebuild
Post by leef82 »
got my arse into gear after work and many months of not progrressing any further, and took the forks back out as ive got a upgrade kit from R.O , im hoping to get the forks stripped tommorow night so i can get the bottoms of to the powdercoaters, im not sure if to go silver or dark grey,
the plan is to take a few other bits to get powdercoated at the same time, screen brace brackets clips ons etc.
but i had a little accident
anyone got a spare forsale?
leef82
Post by leef82 »
parts back from the powdercoaters, just got to order the fork oil seals and bushes from rick then its engine back in time
leef82
Post by leef82 »
had a bit a time of this week so i managed to get the engine back in, and the solid alloy handle bars drilled and fitted
still shit loads to do but thats the worst of it out the way
off the top of my head todo list:
rear shock rebuild
shock linkage raise mod
paint rads and refit........... best stop there the moment ( it could go on for ever
first get the engine running , then..........................................................
Tim400GB
Post by Tim400GB »
Brings a new meaning to home built. :grin:
leef82
Post by leef82 »
got round to refitting the carbs and air box, it took a lot longer than it should as i forgot what a bast##d the carbs are toget into the rubbers, also had probs with the throttle cables sticking so had to take them apart, clean and relube them, the was also abit of a kink on one which i managed to straighten out, even though there working better there still not shutting fully, i think its catching on a bit thats slightly frayed at the end, so ill proberly have to swap them for fresh ones.
bottom rad is repainted and fitted, still need to paint the top one,
still a lot to do, but next step is oil filter, oil, exhaust clamps and then i should be able to fire it up for the first time in two years :grin:
leef82
Post by leef82 »
as it was a nice day i decided to get the bike outside and get busy with the wire brush/drill to give some of the bolts a clean up and polish,
L.Svedberg
Post by L.Svedberg »
Looking very good!!! Nice to see all the fine examples of people taking good care of these fantastic bikes!
leef82
Post by leef82 »
Got the exhaust fitted rads topped up, oil and filter but it wont start! The optimate4 is saying the battery is ok but there is no neutral light and when I hit the start button the starter relay is just clicking so im assuming its just a bad earth, any ideas any one? Im gonna start with fitting the r.o. earth upgrade kit I've got then go from there.....
leef82
Post by leef82 »
Didn't connect the starter motor lead to the relay, still no neutral light so im guessing its the bulb, but the engines turning over so the weekend I shall get out side and attempt to dart it
leef82
Post by leef82 »
got the bike started last weekend for the first time in two years, so nice to hear the sound again, just got a small problem with backfire above 7k
