Page 3 of 8
Re: new to rvf400's and wants more low end
Posted: Sun Jan 24, 2010 7:18 pm
Midrange is also boosted by longer pipework. Get a proper can on it too.
Posted: Sun Jan 24, 2010 7:27 pm
by Drunkn Munky
dr_46 wrote:ok i will take ur advice on that sounds logical....what will extra washers and drilling out the sliders achieve
Extra 0.5mm washers and HRC slide springs will sort the midrange flatspot out so in effect give you better midrange but the 2.5mm drill mod is just for NC30 carbs i belive. But to be honest sounds like somethings wrong if its that guttless low down, or does it just feel gutless because you've just stepped off an R1??
Posted: Mon Jan 25, 2010 3:48 am
by dr_46
hahaha nah it dnt feel gutless because i just jumped of a r1
it just feels like it lags it dont tae off quick maybe its be cause i am 102kgs...i drilled out the sliders...is that wrong?
Posted: Mon Jan 25, 2010 5:08 am
by Cammo
Err, where did you drill exactly? Pic please!
I can't remember what rvf slides look like, but I thought it only applied to vfr slides?
Posted: Mon Jan 25, 2010 5:15 am
by dr_46
well they have the same set up as the vfr but the thing the needels sit in is square not round??
i hope its ok i was under the impression it is.....i just cleaned the carbs and jets they were all clear n not much dirt i am in the process of putting it all back together....also all my main jets are the same al have the same number of holes??? is that normal
Posted: Mon Jan 25, 2010 5:34 am
by Cammo
Ya that is normal on rvf's.
Remember to set your pilot screws while you have the carbs off - 1 & 5/8 turns out.
Posted: Mon Jan 25, 2010 5:44 am
by dr_46
the post in the sticky section said screw all the way and then 2 and a quater turns out which is what i did
Posted: Mon Jan 25, 2010 6:27 am
by Cammo
That's for vfr carbs mate, best to set them to 1 & 5/8 turns out for rvf carbs.
Posted: Mon Jan 25, 2010 7:21 am
by dr_46
woops...dam it...i just finished and took it or a spin its much smother and responsive felt a lil glugish at first but eventually smothed out...ok so tomorrow i have to repeat the ripping off the carbs process and turn the screws 1 and 5/8ths....i am definately not getting the sluggish take off and power kicking in at 7000rpm...its smooth with a kick of power around 10000rpm...does this sound right for what i have done?
Posted: Mon Jan 25, 2010 11:24 pm
by dr_46
what will happen if i leave them screwed out 2 and a quater turns....?
