new to rvf400's and wants more low end
Re: new to rvf400's and wants more low end
Midrange is also boosted by longer pipework. Get a proper can on it too.
Extra 0.5mm washers and HRC slide springs will sort the midrange flatspot out so in effect give you better midrange but the 2.5mm drill mod is just for NC30 carbs i belive. But to be honest sounds like somethings wrong if its that guttless low down, or does it just feel gutless because you've just stepped off an R1??dr_46 wrote:ok i will take ur advice on that sounds logical....what will extra washers and drilling out the sliders achieve
dr_46
hahaha nah it dnt feel gutless because i just jumped of a r1
it just feels like it lags it dont tae off quick maybe its be cause i am 102kgs...i drilled out the sliders...is that wrong?
Err, where did you drill exactly? Pic please!
I can't remember what rvf slides look like, but I thought it only applied to vfr slides?
dr_46
well they have the same set up as the vfr but the thing the needels sit in is square not round??
i hope its ok i was under the impression it is.....i just cleaned the carbs and jets they were all clear n not much dirt i am in the process of putting it all back together....also all my main jets are the same al have the same number of holes??? is that normal
Ya that is normal on rvf's.
Remember to set your pilot screws while you have the carbs off - 1 & 5/8 turns out.
dr_46
the post in the sticky section said screw all the way and then 2 and a quater turns out which is what i did
That's for vfr carbs mate, best to set them to 1 & 5/8 turns out for rvf carbs.
dr_46
dr_46
what will happen if i leave them screwed out 2 and a quater turns....?
