Page 12 of 18
Re: Can you see what it is yet
Posted: Fri Sep 20, 2013 12:58 am
by Morespeedvicar
Looks good that dude.
Posted: Wed Jan 15, 2014 11:29 am
by willandrip
This topic required a bump and an update from Boris !
Posted: Wed Jan 15, 2014 1:15 pm
by Evilchicken0
I polished it a bit last night.
I had just oiled, put the top camchain guide on and fitted the tensioner to the 660.
Posted: Tue Feb 18, 2014 9:36 pm
by chris6409
I see youve got lots of fairing there il love a top fairing and a chain guide
Posted: Tue Feb 18, 2014 10:08 pm
by Evilchicken0
I thought your bike had a top fairing ?
Posted: Wed Feb 19, 2014 7:59 am
by chris6409
Evilchicken0 wrote:Cold huh and the days are short
I've been on the lookout for some downpipes since I got this bike so when a rusty set turned up on the bay I bit the bullet and bought them.
The first job was to get the worst of the rust off them, I used a brass wheel on a slow drill and then gave them a coat of rust killer.
The next weekend I used a fine grit paper with my Mouse palm sander
And another coat of rust killer
I missed the light or it was raining so I had to wait another week before I painted them
I't not the best set in the world but they'll at least be servicable.
Surely there is a hero who could copy the downpipes in stainless and cut and weld the exup onto them to make new forever shiney 3tj downpipes :D
Posted: Wed Feb 19, 2014 8:02 am
by chris6409
About the tank rust ive got abit of minor rust in mine is it worth getting the acid out
Posted: Wed Feb 19, 2014 9:25 am
by Evilchicken0
If you have the acid then maybe - depending on how much there is. Otherwise probably not.
The 3TJ tank has a seam on the bottom so theres a bit on each side that doesn't drain when the tank's on the bike. If water gets in it sits in that bit because it's heavier than petrol, and rusts it. Make sure your tank dosen't have any water in - use a torch and see if there's anything in it.
Posted: Wed Feb 19, 2014 10:50 am
by chris6409
There the smallest amount of liquid in it but it hums of petrol ive tryed to get the last out but like you said its in a place to hard to reach i might try lowering a long pieace of rag in to soak it up
Posted: Wed Feb 19, 2014 11:44 am
by Evilchicken0
It's a bugger innit
Use a long piece so you don't drop it into the tank like I did. Or you can stick a hair dryer in the top of the tank
