Carbon question.......
Re: Carbon question.......
Drunkn Munky wrote:I so want some NC frame and swinger covers in kevlar
Still sorting those out..... the pattern maker was supposed to be doing the moulds.... I will chase him up again...
The 3TJ really needs a hugger, although I'd think the R1's going to be to wide - could it be adapted ???
Evilchicken0 wrote:The 3TJ really needs a hugger, although I'd think the R1's going to be to wide - could it be adapted ???
Well..... it is a bit wide but it could be altered and another mould made...... it would be nice to try so I am making one for Levo to try..... That one was sold and had to go out yesterday... But making another in glass to hack up is easy...
Ok - make me a hack upable one then
Evilchicken0 wrote:Ok - make me a hack upable one then
No problem... it will be glass and have the flanges on to let you cut a bit from the middle then you can put a flat bit of glass along thr flange to help re-join it again so it can be bonded and filled to make a new mould without having to spend 3 days putting flanges back on.... Is that OK??
Sounds good to me.
OK had to fit this in between other jobs.... But here is the first carbon Right hand frame protector... I made this just using some scrap carbon to see how it would turn out.. What do you think?
Here is the left one in Carbon Kevlar. (Levo wanted this specifically...)
I have done some swing arm protectors but was not 100% happy with the moulds so I have a master made to make a new mould this week I hope... I just have to fit it in between a couple of other things....
- hannakournikova
Very nice! i have a busted nc30 frame. Will happily send you the frame spar if you need some for templates
Let me try my mate one more time... he has a frame sitting doing nothing.....hannakournikova wrote:Very nice! i have a busted nc30 frame. Will happily send you the frame spar if you need some for templates
If he doesnt get his act together... then great stuff.... Thanks....
