whats your opinions on my dyno graph ?,now with video..
Re: whats your opinions on my dyno graph ?,now with video..
I would go for the filter mate. The smoking is not cool..but then a 20yr old moto could well be in need of a refresh.
I also note that the air fuel graph is for only a pair of cylinders (front?) as you have the stacks on the moto.
Get a clean filter, get a run, if too rich - whip the lid off and retry...you might find it working lovely..just like my setup that runs 130 mains and no lid.
Martin
Post by Martin »
Waza4 wrote:
vfrman wrote:Dude, something doesn't look right there. You shouldn't have all that smoke when you roll off the throttle. That isn't burning oil is it?
Probably washing the bores.You've got to go smaller on mains .
And the pilots need to come outwards not inwards.
Out on NC35 carbs to lean off
In on NC30 carbs tolean off
Rhory's running '30 carbs....
Too spensiff!!!
Martin
Post by Martin »
It's got to be the filter mate and I suspect the reason for the smoking is just because there's a load of unburnt fuel being sucked through on the over run. Mine used to do the same thing when mine was running rich. It's always possible it may be the valve stem seals but for the ballache it is to replace them I'd let it be if you can't cure it by getting the jetting right. Just pretent you bought Gareths TDM and it's normal to burn oil ;) :lol:
Too spensiff!!!
viper_biker
Post by viper_biker »
Martin wrote: Just pretent you bought Gareths TDM and it's normal to burn oil ;) :lol:
3.5 litres in 3000 miles, the thing drank it like it was fuel :scare:
royster81
Post by royster81 »
to be honest i haven't seen the oil level change so i don't think it's burning oil and i knew the filter was bad so i think (hope) the smoking is just the unburnt fuel and was really surprised to see there was no fires on the dyno,normally when you out on the road and get a bit of pace behind you you can launch fires out the top can,so i think it's just unburnt fuel.
i'll get a new filter from rick and take it to a dyno operator i know who knows his business and i'll take it from there
vfrman
Bike owned: NC30, 1098s
Post by vfrman »
Let us know....
royster81
Post by royster81 »
i will ,i don't like topics that start ,have a bit of a middle then die off before they was a final verdict
vfrman
Post by vfrman »
Sounds like me in the bedroom... just ask my wife! :blowout:
Waza4
Post by Waza4 »
He's lean at the bottom and rich on everything else.
But I didn't know about the 35 carbs thanks.
royster81
Post by royster81 »
i backed in the A/F screws a 1/4 turn so they are now at 2.25 turns out and it's made a bit of a difference but i think the biggest difference has came with the carbs being balanced again,i used Rick O's method and it definately idles better and pulls better through the gears so just need the new filter off him and i'll go bother my local dyno operator.
but more updates to come ...
