Which Screw
M1KE
Re: Which Screw
Thats robinsons foundry prices, but thats just genuine suzuki parts. those numbers are the suzuki part numbers. If you an get hold of carb rebuild kits then the rf600 shares the same float bowl gasket. Give me a minute or two and i might be able to sot you with some springs/washers.
katch
Re: Which Screw
top banana :D thanks
M1KE
Re: Which Screw
Got a full set of springs/washers, you should have o rings in that set you bought from ebay. Pm me your address mate and i'll pop em in the post to you.
- Variablevalves suck
Re: Which Screw
Hold fire!!!! the o'ring goes in first and then the washer stops the spring from cutting it, 9 times out of 10 the washer and o'ring are stuck in their hole and it looks like they arnt there, take a good look and you may find them in place! :)
M1KE
Re: Which Screw
Yeah i just remembered that too when i went to find the ones ive had spare.
katch
Re: Which Screw
I'll go and double and triple check
katch
Re: Which Screw
Oops..
.. i just Fished out a spring and a washer and O-ring from one Carb.
thank you !!! Your are the wise man
guess i just need the Float bowl Gaskets now then
thanks Mike, guess i don't need them now lol
M1KE
Re: Which Screw
13258-33C00 is the part number for the float bowl gaskets, i guess that fowlers will have to order them in so might be worth phoning first.
Re: Which Screw
If the o'rings have stuck in then they are most probs past their best, if you need a set a an supply ya.
Chris.
Chris.
M1KE
Re: Which Screw
You already are supplying him chris lol i linked him up to your ebay link from another site.
