VFR400 NC24 runs for 3 minutes then .....
Pirates Cove
Re: VFR400 NC24 runs for 3 minutes then .....
Post by Pirates Cove »
Oh poop
Mis read the manual looking for the screws on the wrong side of all the carbs DOH!!!
They seem to be all set to 1 turn out.....
:oops:
Cammo
Post by Cammo »
Good stuff, get them set right a good chance that's causing your trouble.
Pirates Cove
Hi.
2.5 turns out is running worse.
seems to be a lot of fuel ......
Mark
superlite
Bike owned: TLS, LB80 x 2
Post by superlite »
Pirates Cove wrote:Hi.
Mark
A lot of fuel where? If it's on the ground, then you've probably undone the drain screws, not the pilot screws.
'Take it to the Back'
Pirates Cove
haha
No the drain screw is on the opposite side of the card.
The exhaust is smelling of fuel.
Mark
superlite
Post by superlite »
Okay, I'm a little confused! There should be four pilot screws in the same spot as the NC30 ones shown in the manual. They should be set at 2 turns out though.
You've obviously had the carbs off, so are all the jets and needles as they should be?
Pirate is right
NC24 carbs have the 4 pilot screws in a different place on the outside of the carbs, they can be adjust with the engien running, but its fiddley.
Start with 2 full turns (720 degrees) out and go from there.
Between 2 and 2.5 turns.
Seat them all so they just about tighten up and back them all out 2 turns and try again.
superlite
Post by superlite »
Neosophist wrote:NC24 carbs have the 4 pilot screws in a different place on the outside of the carbs, they can be adjust with the engien running, but its fiddley.
Ahhhh, I was thinking of NC21 carbs.
el_dudino
Post by el_dudino »
I had a similar problem, traced to the CDI. Try getting hold of one to try before you go down the route of messing your carburation up!
have it set up properly, save the hassle.
Besides it smelling fuel at 2.5 turns out how does it run, pick up wise etc? Do you have the right plugs in it?
Is it smelling of fuel just at idle?
