VFR400 NC24 runs for 3 minutes then .....
Re: VFR400 NC24 runs for 3 minutes then .....
Oh poop
Mis read the manual looking for the screws on the wrong side of all the carbs DOH!!!
They seem to be all set to 1 turn out.....
Good stuff, get them set right a good chance that's causing your trouble.
Hi.
2.5 turns out is running worse.
seems to be a lot of fuel ......
Mark
Mark
- superlite
- Bike owned: TLS, LB80 x 2
A lot of fuel where? If it's on the ground, then you've probably undone the drain screws, not the pilot screws.Pirates Cove wrote:Hi.
Mark
'Take it to the Back'
haha
No the drain screw is on the opposite side of the card.
The exhaust is smelling of fuel.
Mark
Mark
- superlite
Okay, I'm a little confused! There should be four pilot screws in the same spot as the NC30 ones shown in the manual. They should be set at 2 turns out though.
You've obviously had the carbs off, so are all the jets and needles as they should be?
Pirate is right
NC24 carbs have the 4 pilot screws in a different place on the outside of the carbs, they can be adjust with the engien running, but its fiddley.
Start with 2 full turns (720 degrees) out and go from there.
Between 2 and 2.5 turns.
Seat them all so they just about tighten up and back them all out 2 turns and try again.
- superlite
Ahhhh, I was thinking of NC21 carbs.Neosophist wrote:NC24 carbs have the 4 pilot screws in a different place on the outside of the carbs, they can be adjust with the engien running, but its fiddley.
I had a similar problem, traced to the CDI. Try getting hold of one to try before you go down the route of messing your carburation up!
have it set up properly, save the hassle.
Besides it smelling fuel at 2.5 turns out how does it run, pick up wise etc? Do you have the right plugs in it?
Is it smelling of fuel just at idle?
