Electric Fuel Pumps
fzrmadmic
Re: Electric Fuel Pumps
Quick update on this...
I fitted a facet low pressure solid state fuel pump. Cost me £17, seems to run OK on this but won't know for sure until I get it on the road. I made up a simple bracket to fit it off the existing mounts.
Wraith
What...can't believe the Downpipes don't need any welding
fzrmadmic
The only thing on the bike that doesn't need fixing!
fzrmadmic
Getting there!
Work done so far...
New Fork Seals & Oil.
New Pads All round, All brakes bled (Still have braided lines to fit to front)
Engine Oil & Filter
New Plugs, replaced 1 x Coil
Fitted Facet Fuel Pump
Repaired Exup Cables
Repaired Damaged Start Inhibit Wiring & Tidied all wiring and Greased Terminals
Balanced Carbs
Fitted Front Fairing Bracket & Clocks (Was missing)
Now working on the body work so it looks like less of a shed. Hope to see you on track next year!
Work done so far...
Engine Oil & Filter
Balanced Carbs
Wraith
Fresh Coolant?
Oiled Throttle and Clutch Cable?
Fuel filter
fzrmadmic
Yes, Yes and Yes!
