Petrol tank cleaning and sealing
Hogdigerdy Dog
Bike owned: FZR400RR 3TJ, ZX9R fighter
Re: Petrol tank cleaning and sealing
Post by Hogdigerdy Dog »
ADG wrote: I dont really want to risk wrecking the fuel tap or the level sensor..
Hogdigerdy Dog wrote:IMPORTANT make sure you remove the fuel sender and tap before hand. then blank over the holes with rubber and a bit of thin steel plate drilled to suit to stop it leaking
ADG
Post by ADG »
Ill find my tin snips then.
Can the waste fluids be disposed of at the tip?
willandrip
Post by willandrip »
Good for sealing wheelie bin leaks also :grin:
willandrip
OOps. double post
Morespeedvicar
Post by Morespeedvicar »
Hi, I didn't use por15 but it was a resin type stuff. Anyway make sure the tank is as clean and dry as you can get it, I cleaned mine with boiling hot water and washing powder several times and blasted with jet washer for a good rinse out then let it dry very well, try and warm it up maybe with a hair dryer or something.
Ian
