Page 2 of 3
Re: NC30 with Hydraulic clutch.
Posted: Tue Oct 14, 2008 7:09 pm
by duncan
I wonder if Neophyscist is planning on building a special?
Posted: Wed Oct 15, 2008 12:34 pm
duncan wrote:I wonder if Neophyscist is planning on building a special?
Kinda, I am turning my NC24 into a track bike as i've brought an NC35 for everyday use, orignally the 24mods were going to be subtle but now that I have another VFR I can be a bit more relaxed with what I do :) plus if something breaks or doesn't work I still have the other bike to ride.
The hydraulic clutch idea came about after seeing that NC30 and looking through my spares to realise I have one.. it should just bolt onto the 24 motor as the casings are the same. The 400Z idea came about after speaking to one of my friends in Japan who has done something similar to what i'm doing.
Original plan was just to ditch as much as possible, put some bigger wheels (better rubber) on and that would be it (hence the 3 different vfr750 wheels downstairs)
The plan as it is now
Imagine that with the NC35 frontend, in the rothmans scheme, with the NC24 seat (single converted) hydraulic clutch, high-level race exhaust system, and a few other things I have yet to test out! =)
My friends bike over in Japan has a carbonfibre bellypan which looks great! I quite like the idea of that, should improve cooling a bit with the exposed rad too.
Posted: Wed Oct 15, 2008 12:44 pm
fastdruid wrote:Thinking about it, I wonder what they changed, mine has to be the 22860-ML7-000 '88 "FJ" but I have an '89 "FK" which would be the 22860-ML7-010. I wonder if this may be contributing to my clutch slip when cold.
VTR1000 is 22860-MT7-000 Originally designed for the NR750!!!!
Druid
Hmm -010 is deff going to be some kinda revision. It might well be, the slave cylinder should be easy enough to change if you can get hold of one?
And originally designed for the NR eh.. i'll have to see if that fits haha, can say that I have part NR750 lol!
The NR750 uses the ER9 plugs too I think?
Posted: Wed Oct 15, 2008 2:45 pm
by fastdruid
Neosophist wrote:Hmm -010 is deff going to be some kinda revision. It might well be, the slave cylinder should be easy enough to change if you can get hold of one?
I've actually got one, infact while I have a '88 VFR750FJ it was late registered in '89 and currently has an FK engine in and that came with the slave cylinder. I just refitted the FJ slave as it meant I didn't have to bleed the clutch. I've now bought a braided clutch line so I need to do it anyway and I'll swap slaves at the same time. Thinking about it I also have an VFR750FL slave and sprocket cover too.
Anything 'MT7' was designed for the NR750. Have a look here
http://www.vsource.org/VFR-RVF_files/BHondaPCNs.htm" onclick="window.open(this.href);return false; , it shows all the Honda 'PCN's which tell you which machine a part was originally designed for.
The VTR has (IMO) a much nicer master too as it's one with a remote res like the brake on the NC30/NC35, I don't know the bore/ratio so I don't know if the VTR master will work with the VFR slave (or vice-versa).
Druid
Posted: Wed Oct 15, 2008 2:49 pm
Oooh I see, yeah that'd look the business! Oh the 24 has the remote res too.. will have to pop down the lbs and make use of their parts books and check the bore size. ^_^
-edit-
just seen
this
on ebay.. for £30 i might just get it and see :D
Posted: Thu Oct 16, 2008 1:06 pm
And on the subject of NR750 stuff.. look what I found forsale.
Anyone got £290 to lend me? :D j/k
Posted: Thu Oct 16, 2008 1:21 pm
by mattUKNC
Neosophist wrote:And on the subject of NR750 stuff.. look what I found forsale.
Bargain!
I'll take 2!
Posted: Thu Oct 16, 2008 2:30 pm
It's not actually that bad considering the NR750 on ebay fetched 49k, 300 for the master cylinder is a bargain, 14mm id too so it'd work with the std brakes :D
Posted: Thu Oct 16, 2008 2:36 pm
by mattUKNC
It just seemed a lot to me. I'm sure someone will snap it up then. :D
Posted: Thu Oct 16, 2008 3:55 pm
by fastdruid
It's probably identical to the VFR one apart from the lid...
Druid
