strange noise problem, (video)
Deviant400
Bike owned: NC30, Kona Cowan
Re: strange noise problem, (video)
Post by Deviant400 »
its too tight , looks like you got to apply lots of pressure to move the chain
Deviants AM/PM build
viewtopic.php?f=62&t=27307
xivlia
Bike owned: Ducati 749 D
Post by xivlia »
hmm okay, i shall loosen it a bit then. oh and your sig made me laugh :lol:
xivlia
Post by xivlia »
nope. still making the same noise. slackened it off. and its the same. like i said at the beggining. it was already making the noise when the chain was too slack...its coming from the front sprocket...
Deviant400
get the sprocket cover off and have a look see whats going on , does it make the noise if you just rotate the wheel by hand
xivlia
Post by xivlia »
yeah it does, but when it does, the chain has a slight jerk up and down. so it moves fine, for a bit and then every so often the chain make a slight jerking movement and the noise will happen.
porndoguk
Post by porndoguk »
Stuck link, time for a new chain and sprockets
You had it too loose, then too tight.
But it's like flogging a dead horse, the chain is knackered, probably the sprockets too.
For peace of mind replace them as a set.
Clean and lube the chain regularly, O-Ring / X-Ring chains can take more lack of cleaning and lubing, but every other tank is a good idea to give it a wipe and a dash of lube.
xivlia
Post by xivlia »
anyone know how to take the sprocket cover off? i cant seem to take it off ive taken all the screws but it wont budge.
Deviant400
how many bolts did you remove , from memory there is four , 2 at the bottom 1 at the top and 1 in the middle near the speedo drive , give it a few taps all around its proberbly glued on with all the shit thats flung off the chain
xivlia
Post by xivlia »
yep it was pretty much glued on from all the gunk. there was soooo muhc gunk im not kidding the chain was grinding on the pile of gunkk. ive now cleaned it, but the noise is still there while i turn the chain, all the teeth on the sprockets look fine. no idea whats causing this... the chains doesnt look like its got stiff links. they all bend and move freely.
