RVF engine into a VFR frame?
- BillingCBR
Re: RVF engine into a VFR frame?
Drunkn Munky wrote:So the RVF motor goes in a VFR frame with no allingment issues?
Sam, you got a pic of the mounting hole that needs tapping on the RVF engine? may aswell do it while its on the bench.
Not that I experienced mate, just hooked everything back up and went on my way :)
It's the one on the rear cylinder on each side, it looks like it's been filled with weld. Do you want me to sent you the tap to do it with? You might need an 8mm drill bit too.
Yes please mate i'll PM you my addy
- skinnydog0_0
- Bike owned: Penny Farthing
Yes your right DM, you should use a 5mm spacer on the rear if you put the 35 engine in a 30 frame.
