A 4 into 4 exhaust system possible?
Re: A 4 into 4 exhaust system possible?
lol, my bad, 4 to 1 i thought you wrote lad. yeah, will be cooler.
- xivlia
- Bike owned: Ducati 749 D
hehe no problem :)
Whats next on the project list ersan you certainly have a crazy imagination.
Single sided front wheel suspension system? Turbo?
An nsr needs 4 exhausts as its a 2stroke and each cylinder needs a spanny
Have a look at the mv augusta f4 for inspiration if you wanna do 4 outlets.
Rick
Rick
- xivlia
- thunderace
- Bike owned: R6, YZF600R
It would be advisable to get everything down on paper first though (measurements, costs, etc.) and then decide which 'project' to attempt first
- xivlia
yep =) ive already found some 304 stainless steel pipes. cheap 10 quid per meter. but i dont know the exact diameter needed.. plus il need the bigger cylinder part that gets welded on right at the end of the pipe which then gets fitted inside the heads and crush the gaskets in place. so id need to buy some of those AND buy some header clamps to go with it. anyone have any idea where i could buy either? or anyone know the inside and outside diameters of the downpipes? would help a lot =)
- thunderace
With 304 you could get away with a 0.75mm wall thickness for lightness but I would recommend 1.2mm wall to cope with the bends properly
- xivlia
hmm, yes i suppose your right. il have something like 1.2mm thick walls.
intrestin idea,I will keep an eye on this one to get a few tips.
- Bike owned: 1990 NC30
Looks like you're in for some pretty stiff competition.rcv4 wrote:intrestin idea,I will keep an eye on this one to get a few tips.
