Front brake caliper pistons stuck
arsey30
Bike owned: ftr223 650 bros
Re: Front brake caliper pistons stuck
Post by arsey30 » Tue Feb 28, 2012 3:38 pm
Internal expanding pliers should extract them, you could try sitting a short m6 bolt and nut in the bottom of the piston and undoing the nut until nut and bolt bite and grip the piston, but pliers best.
I hold back the first pistons to move, so that the tighter ones can be pushed the furthest out.
If you get stuck, you can come and use my compressor, once 1 piston is out, the fluid holes need sealing to retain pressure to move the other piston.
oldgreyandslow
Bike owned: 1990 NC30
Post by oldgreyandslow » Tue Feb 28, 2012 3:47 pm
arsey30 wrote:Internal expanding pliers should extract them, you could try sitting a short m10 bolt and nut in the bottom of the piston and undoing the nut until nut and bolt bite and grip the piston, but pliers best.
Thanks Dave, it'll be the weekend before I get back to finish these now as work is getting in the way and I'm out for a few days. If I get stuck (literally) I'll give you a bell
micpec
Post by micpec » Tue Feb 28, 2012 11:36 pm
I bought this last week at the annual fair....you mean this?
micpec
Post by micpec » Tue Feb 28, 2012 11:39 pm
Also a brake piston removal plier...
http://www.sealey.co.uk/PLPageBuilder.a ... fulltext=0
V4beermonster
Bike owned: Vfr400,gt750,vfr400/750cc
Post by V4beermonster » Wed Feb 29, 2012 5:32 pm
if they are really stuck and are being replaced i have welded a bolt to the inside of piston put in vice to pull out, heat may have to be used too
