Front brake caliper pistons stuck
- Bike owned: ftr223 650 bros
Re: Front brake caliper pistons stuck
Internal expanding pliers should extract them, you could try sitting a short m6 bolt and nut in the bottom of the piston and undoing the nut until nut and bolt bite and grip the piston, but pliers best.
I hold back the first pistons to move, so that the tighter ones can be pushed the furthest out.
If you get stuck, you can come and use my compressor, once 1 piston is out, the fluid holes need sealing to retain pressure to move the other piston.
- Bike owned: 1990 NC30
Thanks Dave, it'll be the weekend before I get back to finish these now as work is getting in the way and I'm out for a few days. If I get stuck (literally) I'll give you a bellarsey30 wrote:Internal expanding pliers should extract them, you could try sitting a short m10 bolt and nut in the bottom of the piston and undoing the nut until nut and bolt bite and grip the piston, but pliers best.
- micpec
I bought this last week at the annual fair....you mean this?
- micpec
- V4beermonster
- Bike owned: Vfr400,gt750,vfr400/750cc
if they are really stuck and are being replaced i have welded a bolt to the inside of piston put in vice to pull out, heat may have to be used too
