Page 2 of 3
Re: HRC rear brake kit
Posted: Mon Feb 27, 2012 7:12 pm
by Malc
alexwitham wrote:I've been using one for 2 years filled with normal dot4 and never had any sweating. They do fade though but I replace my brake fluid every year and change the hose at the same time.
I've found if the bit of hose comes out of a genuine HRC labelled packet and has some fruity Jap writing on it, it doesn't sweat. If it doesn't, and someone has cut a length of a PVC hose, it does. Just saying... ;)
Posted: Mon Feb 27, 2012 7:14 pm
by viper_biker
Malc wrote:I've found if the bit of hose comes out of a genuine HRC labelled packet and has some fruity Jap writing on it, it doesn't sweat. If it doesn't, and someone has cut a length of a PVC hose, it does. Just saying... ;)
Yes it does. I've only ever had the HRC bits on my bikes and they've all sweated.
Posted: Mon Feb 27, 2012 7:22 pm
by Deviant400
interesting to read all these comments , i wasnt aware there was any issues with the kit , i just fancied something that spruced up the rear brake gubbins,
i bought the kit from padgetts online , each part (4) came in sealed honda hrc packets , even the tiddly spring clip had hrc on the packet 8-) (im expecting 0.0075hp from that clip alone )
Posted: Mon Feb 27, 2012 9:51 pm
by lukemillar
Mine sweats as well and is genuine, but it is still better than the mungo sized OE reservoir and hose.
Posted: Tue Feb 28, 2012 7:33 am
by Malc
OK, so everyones sweats except for mine it seems... what fluid you guys using? Silkolene DOT4 here.
Posted: Tue Feb 28, 2012 10:32 am
There supposed to be dispoable and not designed for road / long term use.
On a GP bike it aids weight loss and you don't need a resevoir and braket and bolt.
I wouldn't use one on the road as it does nothing
Posted: Tue Feb 28, 2012 12:42 pm
by Malc
Neosophist wrote: I wouldn't use one on the road as it does nothing
And it will fail an MOT test, if used as designed.
Posted: Tue Feb 28, 2012 10:37 pm
by dogmatic69
Nope, my bike got MOT and it has one.
Posted: Tue Feb 28, 2012 10:46 pm
by Drunkn Munky
You can get tubes that dont sweat, no idea where from but they do exist
Posted: Tue Feb 28, 2012 10:47 pm
by Deviant400
thats ok my tester is a good pal of mine :whistle:
