HRC rear brake kit
Malc
Bike owned: NC35, 5SL, 3XV, 2MA
Re: HRC rear brake kit
Post by Malc »
alexwitham wrote:I've been using one for 2 years filled with normal dot4 and never had any sweating. They do fade though but I replace my brake fluid every year and change the hose at the same time.
I've found if the bit of hose comes out of a genuine HRC labelled packet and has some fruity Jap writing on it, it doesn't sweat. If it doesn't, and someone has cut a length of a PVC hose, it does. Just saying... ;)
viper_biker
Post by viper_biker »
Malc wrote:I've found if the bit of hose comes out of a genuine HRC labelled packet and has some fruity Jap writing on it, it doesn't sweat. If it doesn't, and someone has cut a length of a PVC hose, it does. Just saying... ;)
Yes it does. I've only ever had the HRC bits on my bikes and they've all sweated.
Deviant400
Bike owned: NC30, Kona Cowan
Post by Deviant400 »
interesting to read all these comments , i wasnt aware there was any issues with the kit , i just fancied something that spruced up the rear brake gubbins,
i bought the kit from padgetts online , each part (4) came in sealed honda hrc packets , even the tiddly spring clip had hrc on the packet 8-) (im expecting 0.0075hp from that clip alone )
Deviants AM/PM build
viewtopic.php?f=62&t=27307
lukemillar
Post by lukemillar »
Mine sweats as well and is genuine, but it is still better than the mungo sized OE reservoir and hose.
Malc
Post by Malc »
OK, so everyones sweats except for mine it seems... what fluid you guys using? Silkolene DOT4 here.
There supposed to be dispoable and not designed for road / long term use.
On a GP bike it aids weight loss and you don't need a resevoir and braket and bolt.
I wouldn't use one on the road as it does nothing
Malc
Post by Malc »
Neosophist wrote: I wouldn't use one on the road as it does nothing
And it will fail an MOT test, if used as designed.
dogmatic69
Bike owned: RVF400 RGV250
Post by dogmatic69 »
Nope, my bike got MOT and it has one.
You can get tubes that dont sweat, no idea where from but they do exist
Deviant400
thats ok my tester is a good pal of mine :whistle:
