How do I remove the quitening gears ?
- skinnydog0_0
- Bike owned: Penny Farthing
Re: How do I remove the quitening gears ?
reverse cylinder jim wrote:Its easy mate and no cutting required.
Remove cams and they are only held in with a circlip. Once its been removed slide off the thinner gear along with the spring and locating dowels.
Did the same with my engine.
you need to remove parts; 9, 10, 11 and 26, 27, 29
http://www.cmsnl.com/honda-rvf400rt-nc3 ... t/E03.html
But it would be worth doing the shims while you have the engine out
- skinnydog0_0
The loss'es you get from the lower gears is minimal, now they are not attached at the cams.Jamboy wrote:What about the lower ones James???
EDIT: Just leave them in place
Good point, but does the bottom one really need to be removed? I left them in as they wont mesh into anything so will not add any drag to the motor if that makes sense?
Edit, You beet me to it mate
Last edited by reverse cylinder jim on Sun Feb 05, 2012 7:13 pm, edited 1 time in total.
- Jamboy
- Bike owned: 916 ,NC30, CBR600RR, RGV250M
Do you have to shim up the cam drive sprocket then to stop it moving on the cam??
Living Life, Living The Dream
I never shimmed/adjusted anything. All seems to be fineJamboy wrote:Do you have to shim up the cam drive sprocket then to stop it moving on the cam??
- skinnydog0_0
I didn't with mine, it's a pretty snug fit so there shouldn'y be to much movement.Jamboy wrote:Do you have to shim up the cam drive sprocket then to stop it moving on the cam??
It does make it sound like a bag of spanners compared to having them in though.
You beat me to it this time
We need to have some buzzers, like they have on a game show
You left them inskinnydog0_0 wrote:The loss'es you get from the lower gears is minimal, now they are not attached at the cams.Jamboy wrote:What about the lower ones James???
- Jamboy
Spoke to my Brother again and the ones he cut off was on his RC30 now wether there different I don't know.
But still will be looking in to this because I like the noise it makes
Yeah it even seems to change the exhaust note alsoskinnydog0_0 wrote:I didn't with mine, it's a pretty snug fit so there shouldn'y be to much movement.Jamboy wrote:Do you have to shim up the cam drive sprocket then to stop it moving on the cam??
You beat me to it this time![]()
Mine used to pass noise tests until i removed them, now it sounds like its trying to eat itself
- Jamboy
It'll be exhaust repacked before each track outting afterwards lol.reverse cylinder jim wrote:Yeah it even seems to change the exhaust note alsoskinnydog0_0 wrote:I didn't with mine, it's a pretty snug fit so there shouldn'y be to much movement.Jamboy wrote:Do you have to shim up the cam drive sprocket then to stop it moving on the cam??
We need to have some buzzers, like they have on a game show![]()
