oil coolers on nc30's
mattUKNC
Re: oil coolers on nc30's
Post by mattUKNC »
Hi Rhory,
I think I've a set of uk spec cooler lines in the garage if you're interested? Here's what I have, I'm sure someone could say for sure.
Matt
royster81
Post by royster81 »
matt111074 wrote: Image
if some one was to buy your oil lines and my oil cooler they them selves would have the makings of an oil cooler that would work with the right effort
but i think i'm going to try the oil/water cooler as i think it'll be the easiest fitted and easiest to get working
mattUKNC
Post by mattUKNC »
OK, no worries.
fastdruid
Regular Member
Post by fastdruid »
8mm?
http://www.watercoolinguk.co.uk/catalog ... Path=39_53" onclick="window.open(this.href);return false;
Druid
royster81
Post by royster81 »
cheers druid ,ordered a few last night
your packet is in the post (I am led to believe)
whoop
I still reckon air/oil is better but you can prove me wrong mate :mrgreen:
royster81
Post by royster81 »
CMSMJ1 wrote:your packet is in the post (I am led to believe)
whoop
to be 100% honest bud i thik you're right but i'm not prepared to go inside a working motor to do it right ,i looked for one of those mocal plates and it was 3times the price of the blade plate !!
so i'm going to try this route first,if it worked for HRC it'll work for little old me ... :? :? i hope
if not i'll just go buy myself an HRC oil cooler... ;)
but i'm surprised not more people have tried an oil cooler on the bikes... :o :o
loving the smilies today :geek:
royster81
Post by royster81 »
speaking to stephen tonight he said that the bikes responed well to oil coolers as every little helps when it comes to losing heat and the oil/air is the best (but we know that) honda probably did the oil/water one as it meant less pipes and tubes around an already compact engine bay
i look forward to trying this and seeing how it helps my road bike as i have found little answer on this forum,seems everyone reads the akhara site but few try it lol :scare:
Cammo
Post by Cammo »
I'm not keen on trying the hrc method because the water temp on my track bike is already at the upper limit, this would only make it worse.
An air/oil cooler would be best, but you'll probably need the uprated oil pump (UK model/maybe nc24) for it to be fully effective.
Big radiators are probably the easiest option to keep both temps in check.
lange
Post by lange »
The oli/air type can be used without upgrading the oilpump as seen in the first 3 pics here:
http://www.rvf.dk/My-RVF-Trackbike/my-r ... bike2.html
My trackbike also ran very hot until the oilcooler was mounted.
Power is nothing without control!
