CBR400 RRR rear shock
Re: CBR400 RRR rear shock
No, I just added table to allow you to choose. I think any shock between 281-310mm will be good for NC29, bettrer, of course, with adjustable length to adjust it depend of you riding preferencesyou telling me those are all ones that will fit ??
how depending on the larger number
e.g. aha YZF R1 2002-2006 300 (+5.5/-0.5) 64.5
is how high they are and the stock is 282? so the higher the number, the taller the bike?
No only taller, it change bike geometry - so highest value make bike better handle the corner, but less stable on straight.so the higher the number, the taller the bike?
- Bike owned: CBR400RR NC23
thanks for explaining :) much appreciated :)
I've been around a while and AFAIK your only option for the 23 is the Graeme France dogbone linkage kit and a cbr600 f3 rear shock.
And it completely transforms the bike. It's a must-have.tanuki wrote:I've been around a while and AFAIK your only option for the 23 is the Graeme France dogbone linkage kit and a cbr600 f3 rear shock.
ive heard you dont need the dogbone adapter to fit the 600f3 shock?
You heard wrong, it's a direct fit to the 29 though.
A shock that can be fitted to the NC23 without modification is from the CBR600 FH, FL, FK, FJ IIRC. It also raises the rear ride height a small amount.DK-Tandy wrote:ive heard you dont need the dogbone adapter to fit the 600f3 shock?
Source: viewtopic.php?f=28&t=26290&hilit=suspen ... c06efbf97d
yeah thats what i meant. I just knew it was a cbr shock that went straight in. I could do with the little extra height so the 600 fh shock will do me fine :)
- Bike owned: CBRs
As you know i have built a few of these beasties and the latest is Ohlins base rear from a Ducati 748R so anything that is mount , length etc compatible can be made to fit ok. I opted for a 15 mm longer free length to allow for the 17 inch NC29 rear wheel in the NC23 frame . Dogbones and link arms are stock and no problem with binding or interfearance.
I have to add , its bloody perfect on the track and was easy to fit, just cost a bit more than a shitty stock Honda part. I was opting for a CBR900 shock till i got the Ohlins.
angry_rob wrote:A shock that can be fitted to the NC23 without modification is from the CBR600 FH, FL, FK, FJ IIRC. It also raises the rear ride height a small amount.DK-Tandy wrote:ive heard you dont need the dogbone adapter to fit the 600f3 shock?
Source: viewtopic.php?f=28&t=26290&hilit=suspension+woes
You should really be looking to raise the rideheight by about 10mm, absolutely transforms the handling.
If you are just looking to replace the shock and add a couple of mm then the shocks you listed would be fine, unless you want to go with the 17" wheel.
