Carb- refitting, new rubbers, easy? is it f&*K!!!!
- Hadies
Re: Carb- refitting, new rubbers, easy? is it f&*K!!!!
As above and make sure the clips are properly loosened off. The clips may be stopping the rubbers from stretching over the carbs.
Start again, make sure the rubbers are properly seated on the engine but leave the clamps loose, clean em up and regrease em, position the clips so you can get to them all, take a deep breath and go for it
- Bike owned: 1990 NC30
I think they may be too loose, the clips ride up over the rubbers when I try stretching/levering them, I'm doing them tight enough to stay in place, but still move but maybe this is actually too loose?Hadies wrote:As above and make sure the clips are properly loosened off. The clips may be stopping the rubbers from stretching over the carbs.
Frustration? FFS I can write a bloody book on it with this bike!
- Smev
- Bike owned: NC30 of course
Where abouts are you in the country? Maybe someone could pop round and help?!!!
Mister Donut Rep NC30
FFS Now every time I try to prise the rear rubbers backwards by using a screwdiver a bit like a shoehorn the fucking clips lift off at the front!!!!!!!!!
Bollox
Bollox
You should put a web cam up in the garage, just for us to see you kick the cat
I really cant see what your doing wrong, ive never had an issue with the clips coming off, have you got a pic of the rubbers on the engine?
I'll bring the laptop in, the poor bloody cat, she's pretty old too.Drunkn Munky wrote:You should put a web cam up in the garage, just for us to see you kick the cat![]()
I have the rubbers off again now, sitting in a pot of just boiled water. Reading Haynes re the alignment/positioning of the rubbers I have them the right way up as far as engine and carb faces go, but should it be small slot towards the front on the front carbs, and small slot towards the back of the bike on the rear ones?
This may be where I went wrong, well one of the ways anyhow as I had the small slot in each case pointing towards the centre of the engine
I'm going to leave the rubbers steeping, change the water every now and again to keep them warm, make peace with the cat and try again in about half an hour or so, in the mentime a cup of tea is in order
If youve got RVF rubbers i dont think you can go wrong with the positioning of them, just put the tappered bits to the outside
Unfortunately I have vfr rubbers, as RO had them in stock, right its all soaked so off for another goDrunkn Munky wrote:If youve got RVF rubbers i dont think you can go wrong with the positioning of them, just put the tappered bits to the outside
- Bike owned: RVF400 NC35
