Twin stack on but funny angle....
Re: Twin stack on but funny angle....
Wernt you the guy that has the full system but didnt want to change the front pipes? if so theres your problem
- Hadies
I think its a Tyga? Asked Gavin if he can sekk me a hanger. When you loosen everything it moves loads so I reckon it just needs a hanger to pull it all together.
Yes I was and you are probably right... Ok tomorrow I will be mostly changing the front pipes..... Lazy bas**rd I know........
- Bike owned: CB-1, MSX125
I daresay that's so far out, that if you pulled it in with a sturdy bracket, you would end up with stress fractures on the downpipes somewhere.
Why don't you fit it right? If you are fitting a nice system then you might as well get it spot on rather than nearly.
Loosen the pipes and get jiggling them - it will fit better than that and using a bracket is not going to work long term.
