Page 2 of 2
Re: leak please help
Posted: Thu Apr 14, 2011 2:19 pm
by sp00ka
Thanks 4 all the help I'll get on it later and see were the leak is coming from ,
Posted: Thu Apr 14, 2011 9:51 pm
by sp00ka
Engine is all cleaned down :) had it running for half an hour and could see any leak , I'll leave it over night and update if any more news , I did notice when running bike over it rev up to 3rpm and back down to 1rpm, I not sure if that's got any think to do with no air filtter or ever since messing with that vacuum pipe on cylinder ,
Posted: Fri Apr 15, 2011 11:42 am
bike will not run properly without an air filter.
Posted: Fri Apr 15, 2011 5:24 pm
by sp00ka
I have cleaned all the engine mint and there is no signs from any were of fulids ?? Strange because were the red marks I point out , there was a constant leak every morning ?
Posted: Fri Apr 15, 2011 6:43 pm
by VFR400+
Sure you can get an additive for the coolant that when used with a uv light glows to help show where its come from, cant remember what its called though. If you found the leak in the morning it may only leak when cold as once warm bits expand. Had that issue before with water pumps, just a though, may be well off the mark
Owned a fair few rovers which are know for hg failures so traced a few coolant/oil leaks before
Posted: Fri Apr 15, 2011 6:51 pm
by sp00ka
Any advice is helpful mate :) thanks
Posted: Mon Apr 18, 2011 6:08 am
by krisztian_andre
Condensation?
