3tj wheel/brake issue....
Re: 3tj wheel/brake issue....
i think it's 10mm aswell!
From the hub matiing surface to the outside of the disc carrier = 9.37mm
now heres a question...
have I got the right calipers???......
the ones I have, have 4 pistons, 2 big and 2 little...
are they the correct ones????
ayone got a link to a parts diag for a 3tj??
ALex.
ALex.
- Kayla850
- Bike owned: Sunn Tzar S2
If you've got standard 3TJ forks in I don't think it's possible to have the wrong calipers. I think all of the 83mm Yam calipers are the same.alext wrote:now heres a question...
ALex.
Can you post up a pic of the casting marks on your wheel?
www.projection-racing.com
www.pjcfasteners.com
Are the forks on the bike ???
If not maybe you have the fork bottoms rotated - the spindle goes form right to left as you sit on the bike.
- cagiva996
if you need a set of 3tj discs ive got 2 or 3 pairs hanging around,pm me if you need some.
look in the sticky for manuals, pretty ure there's a caliper diagram in there. they should be sumitomo (or however you spell it) .
ok next issue I have is at the back !!!
having got a 3tj rear brake off Taggy (cheers!) I need to fit it and the spacing is quite different for the caliper carrier, so I need to make up a spacer and also something to reduce the 3tj's caliper carrier from a 20mm axle down to the 1wg's 17mm.
inside the 1wg sprocket carrier there is a spacer that spaces the carrier out that fits inside the 20mm id bearing in the carrier.
I could easily modify one of these to do what I want - does anyone have one lying about they'd be willing to part with?
Ta
ALex.
Ta
ALex.
Why not look at going the other way round this problem and use the 3TJ 20mm spindle ???
I'm sure you can find some tensioner blocks that will fit the swingarm, maybe from a FZR1000 if they use a 20mm spindle
Hang on a minute - are you using the RD's swingarm and if so what does it look like ???
