Page 2 of 3
Re: NC30 Engine build, AKA Project viva Espana
Posted: Thu Feb 17, 2011 8:30 am
by CRM
Tony, so you plan on taking this engine to spain then ?
All i can say is genuine head gaskets, and if it overheated here in the UK, its going to proper cook over there.
expect high 30 temps and no air, then expect vertical rain that hurts when it hits you, then snow around the next corner.
weather is from one extreme to the other over there.
Posted: Thu Feb 17, 2011 9:32 am
by Drunkn Munky
Well im hoping the to cure the overheating issue and something obvious thats causing it will jump out at me during the build, anything that needs replacing along the way will be plus the fitment of the RVF pistons needs the motor to be striped further so nothing is going to be left unchecked, what can go wrong
Its no use bringing the bike with the motor thats currently in it, you'd all be carrying spare fuel cans for me and lapping the valves back in half way through.
By the way if anyone has any ideas as to what might cause it to overheat then let me know, i suspect it just wasnt put back together right by the previous owner or someyhing silly overlooked like a nakered rad cap.
Posted: Thu Feb 17, 2011 9:42 am
by dx400r
Good luck with the build matey. I got a motor with '35 heads done by mike at BMC. Will try and let you now how she goes
Posted: Thu Feb 17, 2011 12:17 pm
by CRM
tony, wasnt the water pump spigot sheared off was it ?
Posted: Thu Feb 17, 2011 12:57 pm
by Drunkn Munky
CRM wrote:tony, wasnt the water pump spigot sheared off was it ?
Nope its in excellent condition, im gunna start splitting the cases today to fit the pistons so nothing is going unchecked.
I take it i'll need to get the bores honed for the RVF pistons??
Posted: Thu Feb 17, 2011 2:04 pm
by skinnydog0_0
I run 35 heads and coms on my uk spec 30 engine and it is sweeeeeet as. The uk oil cooler keeps her really cool, i dont run a fan admittidly, but when i am going along it never gets above 1/3 temp. much cooler than the standard engine i had before.
Are any of the water passages in the heads blocked, or temp sender fecked?
Posted: Fri Feb 18, 2011 7:23 pm
by Drunkn Munky
Posted: Sat Feb 19, 2011 10:12 am
by jim157
Interesting thread. What's the benefit of using RVF pistons?
Posted: Mon Feb 21, 2011 12:35 pm
by dx400r
Sightly higher compression.
Posted: Mon Feb 21, 2011 1:01 pm
by Variablevalves suck
DM, are the broken valves on the same pot as the different piston is on? if so you can assume the piston was changed becaue of the valves. Worth looking down the bore to see if its ok.
