Uh Oh!....Help/Advice urgent. *Pictures Now Added*
force-v4
Bike owned: Far too many now!
Re: Uh Oh!....Help/Advice urgent. *Pictures Now Added*
Post by force-v4 »
Ive seen worse welded up. its worth a shot, its a 50/50 thing, you might be lucky, you might not, i'd get a head just in case. You weld a little block on, drill it & tap it - i cant see that piece of broken rubbish being welded back on. :whistle:
veefer400
Bike owned: Ducati 900SS, 1978 Cafe 400/4
Post by veefer400 »
Morespeedvicar wrote:Hi, could you drill down a bit further and tap the hole and use a longer stud? you have to be mega carefull not to hit the water jacket/oil ways! maybe worth a try if heads nakered already.
Ian
This may work if you use the header clamp to line the drill up? I fear access may be a problem tho...
Überbodge: Is there any way you can strap the header to the head by using a very long jubilee-clip arrangement around the exhaust & back of the barrels so the bike can still be ridden without the header blowing?
ChowderV4
Bike owned: 94 Fzr 400 3TJ ZXR400 Racer
Post by ChowderV4 »
the header still has 3 nuts holding it on and i mate sure not to over tighten them so they pulled that part of the manifold away, so hopefully it will be ok for a short period of time.
The old man said there should be enough spare metal there to drill and tap it and just use longer studs.
I kinda want to avoid a new head as much as possible, as i neither have the time/skill nor the garage to drop the engine and replace the head. If i did i would have no form of transport for however long.
Im going to re-fit the rear pipes tomorrow as long as the weathers good and i'll check if/or how much its blowing.
You can swap the head with the engine in the frame...it is not as difficult as you think... ;)
A dirty bodge for now but I'd be worried about further damage and cracks spreading with the additional vibration.
sort it in the summer.. :mrgreen:
ChowderV4
Post by ChowderV4 »
CMSMJ1 wrote:You can swap the head with the engine in the frame...it is not as difficult as you think... ;)
Oh god im not leaving it until the summer, if i have to swap a head i will, it will be done by spring.
gives me a chance to do valve clearances too....first i need an abba stand though. Currently borrowing one of a friend, they are amazing!
Alex_ludd
Bike owned: Giantco 125, ZZR400n , NC30
Post by Alex_ludd »
I feel your pain I have the exact same problem on my right down pipe
I'm runnng a full tyga system so its blowing a lot
I did a rough repair job in august mines not as bad as yours I only lost half the thread
Did a weld job to fix this has now failed :( so I'm looking at a new head
And I just did my valve clearences so not happy
just wondering if you guys know wether all rear nc 30 heads are interchangeable i.e. a later head
on an 89 engine
Cheers alex
All heads the same. ;)
If you want to ride down you can come and have a spare one of mine...todmorden in't that far away..
I'd repair it with some lumiweld etc rather than replace the cylinder head if you can't afford the time / expense of a stripdown.
http://www.frost.co.uk/item_Detail.asp?productID=8823
It will be more than good enough to hold the exhaust stud providing you dont' torque it up to the extreme.
Very similar to this kind of thing.
Alex_ludd
Post by Alex_ludd »
CMSMJ1 wrote:All heads the same. ;)
</BR>
</BR>If you want to ride down you can come and have a spare one of mine...todmorden in't that far away..
That would be great I should be free this weekend if that's ok with you
Neosophist wrote:I'd repair it with some lumiweld etc rather than replace the cylinder head if you can't afford the time / expense of a stripdown.
</BR>
</BR>http://www.frost.co.uk/item_Detail.asp?productID=8823
</BR>
</BR>It will be more than good enough to hold the exhaust stud providing you dont' torque it up to the extreme.
</BR>
</BR>
</BR>
</BR>Very similar to this kind of thing.
I used lumi weld the to repair it first worked fine but its now failed I could do it again
but it will probably fail again
Cheers alex
