Foolish exhaust idea for my NC29
sa.racing
- Bike owned: NC29 Race
Re: Foolish exhaust idea for my NC29
Fitting a baffle into a link pipe won't reduce the noise by much as the idea of a baffle is to redirect the sound waves back into the silencer to be absorbed by the packing,
Tubbygit
- Bike owned: RVF400, CB1300, Hornet, CBR250
sa.racing wrote:Fitting a baffle into a link pipe won't reduce the noise by much as the idea of a baffle is to redirect the sound waves back into the silencer to be absorbed by the packing,
Thanks mate, that explains why having the baffle in on my can-less test run made so little difference compared with my previous experience of the difference a baffle has made when running normal (race) end cans.
That did have me a little puzzled.
amorti
- Bike owned: CB-1, MSX125
Here's a couple of shots I took while messing about with the link pipe on my previous CB-1 with NC29 'arm.
Maybe you could do similar if the angle of your link pipe allows it? The chopping off is a bit permanent mind, and I didn't have the nerve to chop it shorter and have it really sit under the engine, so I just put the link pipe S-bend back in. Would've looked good I reckon, but as say, just didn't have the nerve to make the last cut.
- lloydspencer
- Bike owned: NC29, RS250, Goose, RGV250 VJ2
Did that exhaust angle not affect lean angle?
When your Aprilia RS250 is more reliable then your girlfriend then you know it's time for her to go.
amorti
It was only like that for a test, and if I'd have cut the downpipe right off, the stubby pipe would've been tucked in quite tight to the engine and swingarm, so probably would've been OK.lloydspencer wrote:Did that exhaust angle not affect lean angle?
Troyus
- Bike owned: x2 CBR400 NC29s
I have had a similar thought regarding a cut down exhaust for my cbr in order to show off my lovely polished gullarm- check out this exhaust system that I found being sold with a cbr on ebay. hopefully will be able to obtain it if the highest bidder has no need for it- either that or take a hacksaw to the original (but rusty) B4 any1 says anything I have an MOT passable exhaust back up- thoughts please
Troyus
Oh I forgot to mention the can is the original tin from a cbr600rr with a 90 degrees exit / side port
amorti
Looks awesome, I can't see the buyer wanting rid of it though.
I have a spare pair of CBR900 mudguard clipsto offer if you do contact the buyer.
Troyus
I am keeping my fingers crossed about that! I have detailed / close up pictures of the exhaust from various angles as well as some details of how to build the system for myself- may make some alterations to this exhaust tho. considering not having the side exit port - just having the exhaust out straight back- only problem there would be if the engine coughs out any oil it would land neatly on the rear tyre (would make things interesting!!!)
amorti
The extra heat on your tyre would be a bad idea, IMHO.Troyus wrote:I am keeping my fingers crossed about that! I have detailed / close up pictures of the exhaust from various angles as well as some details of how to build the system for myself- may make some alterations to this exhaust tho. considering not having the side exit port - just having the exhaust out straight back- only problem there would be if the engine coughs out any oil it would land neatly on the rear tyre (would make things interesting!!!)
