Front Brake Issue
pf85
- Bike owned: VFR400 NC24
Re: Front Brake Issue
Yes there is a bit of play when I lift the front wheel off the ground. I'll order a set of new wheel bearings and hopefully that should sort itgraham72 wrote:You need to get the front wheel off the ground and see if there is any play/movement in your head bearings, if there is, you will feel/hear knocks over bumps!pf85 wrote:I checked the front guard and its secure and doesnt rattle.hunter wrote:Sounds like a front mudgard rattle to me,
Check the mounts on the forkleg.
I think the front bearings need changed as there is a slight groan at times but would this cause a knocking noise when going over bumps??
