jap spec bulbs
Re: jap spec bulbs
Totally agree.Neosophist wrote:most of the cheap chinese junk is really unreliable...
There are some German units around these parts that are available for the same price as the Chinese units. I'm tempted to try one, only because I have a single headlight.
- mattUKNC
Re: jap spec bulbs
I might have a couple at home from when I rebuilt my UK bike up to spec (previous owner had jap light units fitted)
If you're still after some I'll dig them out.
- banoffee
Re: jap spec bulbs
just recently fitted a relay and H4 bulbs. well worth the effort, didn't take long at all
graham72
- Bike owned: NC30,
Re: jap spec bulbs
I too recently did the relay and modded the bulb mount, my lights are soooo much better now
Used the H4 philips x-treme bulbs, so impressed with these bulbs Im fitting them to my car next week!
I have two jap spec bulbs, make me an offer!
RobTriskele
- Bike owned: 1991 NC30
Re: jap spec bulbs
Good post Neosophist. Thanks for the info. I haven't had achance to ride my bike in the dark yet so Im not sure if the Jap bulbs are adequate. I need to get a H4R bulb asap to get my bike thru its MoT next month. Il look at modifying the lights/installing the relay during the summer/autumn ready for winter riding.
Re: jap spec bulbs
Yes.. Philips Xtreme bulbs ROCK.. they make a world of difference.graham72 wrote:I too recently did the relay and modded the bulb mount, my lights are soooo much better now
You know you can just modify a H4 bulb to fit? Snip the two lower tabs off a H4 bulbs and put a nail across the back of it to hold it in place... it'll get you through an MOT just fine :-)RobTriskele wrote:Good post Neosophist. Thanks for the info. I haven't had achance to ride my bike in the dark yet so Im not sure if the Jap bulbs are adequate. I need to get a H4R bulb asap to get my bike thru its MoT next month. Il look at modifying the lights/installing the relay during the summer/autumn ready for winter riding.
Only problem without adding a relay for the H4 bulbs is that prolonged use will likely melt your lightswitch overtime.
This is becuase the standard 35 watt bulbs run through the switchgear, the 55 watt UK bulbs have a seperate relay to handle the extra current.
If you really want the 35watt Jap bulbs Cradley Kawasaki sell them for £7.95 on ebay :-) (the zxr400 have the same bulb)
The Relay Mod and some Philips X-tremes will cost you about £30 and will be the best money you can spend on your bike :-)
You can get Metal LaserCut Adapter rings from off ebay that convert the bulbs to save you using a nail.. but I just snip the tabs off and use a nail for mine.
Mr_Fen
Re: jap spec bulbs
who from or how do you make this relay mod kit?
Re: jap spec bulbs
http://www.vsource.org/VFR-RVF_files/NC ... mRelay.htmMr_Fen wrote:who from or how do you make this relay mod kit?
Low Beam relay mod :-) Explained with pictures.
http://webpages.charter.net/bpeloquin/H4mod.html
How to modify the H4r bulbs to fit H4
- banoffee
Re: jap spec bulbs
H4 Osram nightbreakers here as was impressed with them in the car. Only slightly blue-ish tinted glass with silver ends so don't stand out at all but v bright and only a slightly more white beam so perfect for what I wanted to achieve
Re: jap spec bulbs
I used to use Nightbreakers but there not half as good as Philips Xtreme :)banoffee wrote:H4 Osram nightbreakers here as was impressed with them in the car. Only slightly blue-ish tinted glass with silver ends so don't stand out at all but v bright and only a slightly more white beam so perfect for what I wanted to achieve
