30 engine in rvf jetting problems now
Old Painless
Re: 30 engine in rvf jetting problems now
DO you have a picture of this flap thing your talking about ?
This forum is in a new era my friend, and I claim my rightful username back!CMSMJ1 wrote: Right, that's it Dataracer, Cammo, whoever ou are!! Jjst bloody stick to a name will you!
Or maybe it was just time for a change.
CMSMJ1 wrote: I run a complete airbox on my race bike - all std. runs lovely
I run no airbox at all on my road bike and it is also lovely!
Arse about face I know...and I'll probably swap them over sometime but I have them both running great
- CRM
Here in the uk to change your name it costs you a fortune. bit cheaper on the forum, so shall we call it say £50
seriously stick with cammo, cammel, stickshit, shitoffastick, slimfast, its upto you
But update your Sig so we can keep track :DCRM wrote:Here in the uk to change your name it costs you a fortune. bit cheaper on the forum, so shall we call it say £50
- skinnydog0_0
- Bike owned: Penny Farthing
I have noticed on other posts that it is not recomended to drill the carb slides to 2.5mm on RVF carbs.
Why is that?
Why is that?
- superlite
- Bike owned: TLS, LB80 x 2
Technically, you can drill them, but it's not advised. 2.5 mm is recommended for NC30s , but NC35s run different carbs and very different slides. The hole diameter controls the vacuum which determines the speed that they 'slide' at. If you get it wrong, the slide action will be out of sync with your throttle input = not good. HRC brought out slide springs for the NC35 which are a tried and tested way of getting the same effect. Rick Oliver still sells replicas I believe?skinnydog0_0 wrote:I have noticed on other posts that it is not recomended to drill the carb slides to 2.5mm on RVF carbs.
Why is that?
- skinnydog0_0
Okay, thanks superlite.
I have tried the bike with standard airbox, and 110 main jets, had to jump the bike from the car, then it ran ok. it wouldn't idle very well it would yoyo from 1.5k to 2.5k and wouldn't take any choke, as soon as i tried to put some choke on it would stall. it revved ok up to about 10k then struggled to the red line. but i dont think the battery not being very good is helping matters.
Will leave the battery on charge over night see if that makes any difference.
