NC35 track bike dieing at end of session
Re: NC35 track bike dieing at end of session
ok, many thanks again guys for the input.
Seems like i will have to have a look at the carbs. So ill have to do a bit of research here to find out what im looking for.
No i just need to find the tie to do it between now and late May when i have my next track day lined up.
Any other Sydney based Aussies heading to Eastern Creek in late May?
Stu, the culprit might be something as simple as the pilot screws being incorrectly adjusted (they should be set at 1 + 5/8 turns out for your setup).
Using HRC emulsion tubes might also help your symptoms, but check the PS setting first.
Thanks mate, ill give it a shot as soon as i can.DataRacer wrote:Stu, the culprit might be something as simple as the pilot screws being incorrectly adjusted (they should be set at 1 + 5/8 turns out for your setup).
Appreciate the input.
Stu
