Injected VFR/RVF. Possible ?
Re: Injected VFR/RVF. Possible ?
The efi CB400 has been around for 2-3 years, sure to be some crashed bikes.PARUS wrote:NO one mate in Japan for now. Too fresh bike for braking...DataRacer wrote: Honda itself does some that will bolt straight onto an nc29 on the EFI CB400 Revo.
Yes difficult to find, but if you have a contact in Japan they should be able to get hold of a set fairly easily from a breakers.
I'll ask a friend in Japan later in the week if he can do a ring around the breakers if you want.
PARUS
1. The first problem really I don't know how to fit it in head or somewhere else.racesupplies wrote:Hello Parus,what problems are you having with the camshaft sensor? If you have one I have a head and cam cover here I could perhaps modify for you.
2. Second - we need modulator that not VFR nor CBR have. Planning to grind something like picture below
[youtube]http://www.youtube.com/watch?v=RtqeOYNgn8A[/youtube]
And what kind of sensor should be - most of the motorcycle has inductive sensor.
[youtube]http://www.youtube.com/watch?v=RuIislTGOwA[/youtube]
racesupplies
Are you looking for Hall effect magnetic,or optical trigger? Could it not be run on crankshaft.
Holy shit dude, i just typed a reply to this thread that was almost word for word IDENTICAL to your replyDataRacer wrote:The efi CB400 has been around for 2-3 years, sure to be some crashed bikes.PARUS wrote:NO one mate in Japan for now. Too fresh bike for braking...DataRacer wrote: Honda itself does some that will bolt straight onto an nc29 on the EFI CB400 Revo.
http://roadstercycle.com/yamaha_vmax_fu ... cv_car.htm" onclick="window.open(this.href);return false;PARUS wrote:1. The first problem really I don't know how to fit it in head or somewhere else.racesupplies wrote:Hello Parus,what problems are you having with the camshaft sensor? If you have one I have a head and cam cover here I could perhaps modify for you.
You could always buy a kit like this
- mruehl34
You have a cranksensor=triggerwheel. The oem ignition wheel.PARUS wrote:1. The first problem really I don't know how to fit it in head or somewhere else.racesupplies wrote:Hello Parus,what problems are you having with the camshaft sensor? If you have one I have a head and cam cover here I could perhaps modify for you.
Michael
racesupplies
What size throttle bodies would you need?
- mruehl34
We try 34mm.racesupplies wrote:What size throttle bodies would you need?
Michael
racesupplies
My flatslides are 32,is 34 to compensate for the butterfly?
fastdruid
It seems every FI bike has larger throttle bodies than it would have carbs. So 34mm sounds about right.
You could try see if the TB's off a 2009 Kawasaki Teryx 750 FI might fit.
Druid
Druid
