Injected VFR/RVF. Possible ?
Cammo
Re: Injected VFR/RVF. Possible ?
Post by Cammo »
PARUS wrote:
DataRacer wrote: Honda itself does some that will bolt straight onto an nc29 on the EFI CB400 Revo.;)
Yes difficult to find, but if you have a contact in Japan they should be able to get hold of a set fairly easily from a breakers.
NO one mate in Japan for now. Too fresh bike for braking...
The efi CB400 has been around for 2-3 years, sure to be some crashed bikes.
I'll ask a friend in Japan later in the week if he can do a ring around the breakers if you want.
PARUS
Post by PARUS »
racesupplies wrote:Hello Parus,what problems are you having with the camshaft sensor? If you have one I have a head and cam cover here I could perhaps modify for you.
1. The first problem really I don't know how to fit it in head or somewhere else.
2. Second - we need modulator that not VFR nor CBR have. Planning to grind something like picture below
[youtube]http://www.youtube.com/watch?v=RtqeOYNgn8A[/youtube]
And what kind of sensor should be - most of the motorcycle has inductive sensor.
[youtube]http://www.youtube.com/watch?v=RuIislTGOwA[/youtube]
racesupplies
Post by racesupplies »
Are you looking for Hall effect magnetic,or optical trigger? Could it not be run on crankshaft.
Post by Neosophist »
Holy shit dude, i just typed a reply to this thread that was almost word for word IDENTICAL to your reply :ninja: freaky as hell.
http://roadstercycle.com/yamaha_vmax_fu ... cv_car.htm" onclick="window.open(this.href);return false;
You could always buy a kit like this
mruehl34
Post by mruehl34 »
You have a cranksensor=triggerwheel. The oem ignition wheel.
Michael
racesupplies
What size throttle bodies would you need?
mruehl34
Post by mruehl34 »
racesupplies wrote:What size throttle bodies would you need?
We try 34mm.
Michael
racesupplies
My flatslides are 32,is 34 to compensate for the butterfly?
fastdruid
Regular Member
Post by fastdruid »
It seems every FI bike has larger throttle bodies than it would have carbs. So 34mm sounds about right.
You could try see if the TB's off a 2009 Kawasaki Teryx 750 FI might fit.
Druid
