vfr 400 nc30 fuel in the oil.....WHY? will not start
- Bike owned: vfr nc30
Re: vfr 400 nc30 fuel in the oil.....WHY? will not start
Thats is incorrect. My fuel tap is modified, but it stops the flow when the tap is off.rc211v wrote:you can't see if it has been modified unless you open it up. best thing to do is to disconnect the fuel hose and see if fuel continuously flows even if the tap is in the OFF position.
The modified fuel tap always flows when the tap is on, while the standard tap requires the tap to be on, AND a vacuum at the pipe that leads down to the "auto fuel vacuum valve tube" on the engine.
You only need to disconnect the tank from the bike, put it above a jug and turn the tap on to find out if its modified.rc211v wrote:you can't see if it has been modified unless you open it up
Stickshift: Quite right. Depends if its modified or not.
I agree with CMSMJ1. Fix the carbs or you'll always have some fuel trickling into your engine.
I actually had this problem to a certain degree with my old carbs and only fixed it *after* changing the oil. Perhaps I should change the oil again. Is the rule: If in doubt, change the oil? :) My filter is quite new, should I change it too or just the oil?
its not immediately obvious without taking the fuel tap to pieces.
You can buy a repair kit for it. There was a split rubber diaphragm in mine that was letting the fuel flow anyway.
But please if the fuel in your oil and the resultant blue smoke hasnt injured your motor too badly any further starting attempts before you change that oil will finish it off.
right! I forgot, I was talking about my knackered fuel tap. silly me.Lope wrote:Thats is incorrect. My fuel tap is modified, but it stops the flow when the tap is off.rc211v wrote:you can't see if it has been modified unless you open it up. best thing to do is to disconnect the fuel hose and see if fuel continuously flows even if the tap is in the OFF position.
Ok, first thing do *not* try and run it.
You need to drain the oil, remove and replace the oil filter, if you do not you run the risk of fscking up the engine.
Druid
Druid
