Page 2 of 2
Re: RVF front end help?
Posted: Fri Jun 13, 2008 2:19 pm
by robefumi08
I am sure i have seen people do this conversion?
Does any body know the length from inside the bottom of the forks where
the wheel goes, as it is different to that of the NC35 and NC30.
Was wondering what it was for the ZXR400 and NC35
Posted: Fri Jun 13, 2008 2:33 pm
basically, as far as I see it, it is the difference between the RVF spindle and the NC spindle added to the spacers change for the ZXR to NC sheel and spindle swap (as on the "normal" conversion)
Hope that makes some sense..it makes sense in my head and the info is probably out there.
End of the day - why not dry fit it all, measure it and then get some spacers sorted? Sometimes you have to be the first in a process and it might be that you are in this case....
good luck !!
Posted: Sat Jun 14, 2008 5:02 pm
by robefumi08
Kind off will dry fit it. and measure it.
I know if you fit the zxr 400 forks in the yokes you need: two 28mm spacers to fit an NC30 wheel.
Assuming the bottom of the forks are similar and the only thing different is the yoke
size then i am guessing that it may be 28mm both sides?
I have one 28mm spacer will see how much is left over.
if anybody finds out before me feel free to post it :D
