clock colour change
Re: clock colour change
ok the nc24 dials are 77/78mm across... these should fit but mite need some backsing behdind them to hide the clocks :)
- royster81
is there any more pictures of these fitted to bikes and night pictures also.
VfRTeddy
- Bike owned: Vfr400 nc24
Master Fen received the damaged ones yesterday gunna see about fitting them over the next week an will get some pics an let everyone know if they fit the old nc24 would you be able to keep a pair back for me??
Mr_Fen
i have a set saved for you
- NGneer
hello mate - are mine on the way?
Clocks stripped in atticipation
VfRTeddy
ahhh sweet is it easy to take the clocks apart?
Yep! (NC24...)VfRTeddy wrote:ahhh sweet is it easy to take the clocks apart?
Undo the small Philips screw thats hidden in the end of the tripometer reset knob, unscrew the screws and bolts from the back (the front ones are dummys)
The whole lot then drops apart.
This part is crucial to proper finger alignment... if you move the speedo needle you'll see how the back moves..
I set my needle to 80k (50mph) and tape the back in place, if you've done it right when you let go of the needle it wont fling back to zero.
Now using equal pressure from opposite sides prise the speedo needle up and off the shaft its on.
Undo the two philips screws securing the dial, and swap them over.. the needle stop in the old dial can be pulled out with pliers and force if you need it for the new dial.
line the speed up with the now 50mph mark and push the needle on firmly but not hard enough to bend the shaft.
remove the parcel tape and your done
VfRTeddy
ahhh sweet cheers Neo will post pics of wat it looks like if it fits
unless u've already got the new dials on ur 24
cheer
Ben
cheer
Ben
Post some pics up! i'd be interested to see.
I have dials on that I was making myself. There a good replica but theres a little light bleed you can see at night that i'm not happy with. i'm hoping to cure this before I make some that' i'd sell (when i get some time to fart about with toners etc)
VfRTeddy
lol yer gunna give it ago on mon so will let you know an attempt to post some pics up an bit of a thread deveation i know an apologise in advance
but any ideas where to get most fairings for the 24 from?
Ben
Ben
