How to fit the 600 into the 3tj
Re: How to fit the 600 into the 3tj
Post by Evilchicken0 »
There was only one year of Foxeye and as far as I know it didn't have a throttle sensor.
If you use the TJ loom you'll have to cross some wire to the CDI and the oil sender's in a different place - have a look through this thread, I think it came up before
bendy3
Bike owned: FZR400RRSP FZR400 HYBRID RRSP
Post by bendy3 »
Ive looked at the carbs and they're 4tv (thundercat) carbs so no probs now, the engine is in and I'm going to use the 4jh loom.
bendy3
Post by bendy3 »
The project is coming along now, Ive got round the problem of keeping the engine inline by not using a conversion plate on the left side of the engine. Instead I have welded 2 new lugs below the original 1's then drilled and tapped them, I have photos but cant work out how to put them on?
http://www.400greybike.info/newforum/faq.php" onclick="window.open(this.href);return false;
You need to upload the pics to photo bucket (or somewhere similar on the web) copy the "direct link" and paste that between the ][ in the "img img" thing
hunter
Post by hunter »
Just thought I would show the latest acquisition for my hybrid,I can get it on the dyno shortly, just want to see the motor's output (BHP) before i strip and re-build, and port the head
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWNX:IT" onclick="window.open(this.href);return false;
cagiva996
Bike owned: 2 FZR4/6,FZS600,YZFR1
Post by cagiva996 »
let us know how you get on fitting it,ive got r6 headers on my track hybrid that were modded by the previous owner and ive been considering it for my road hybrid to try and release a few more bhp.it would be nice to see whats involved!!nice set of headers by the way.
hunter
Post by hunter »
cagiva996.i have fitted the pipes but had to cut the balance pipe that attached the two middle
pipes,easy on these because the header pipes sleeve into the collectors,i think these may be
micron pipesImageImage
cagiva996
Post by cagiva996 »
nicely done! were they just a staight bolt on?
hunter
Post by hunter »
Yep,apart from cutting the small balance pipe in the front,(see pic on right)it was straight fit.
mogster
Post by mogster »
You might find things a bit tight when you try to put a fairing on . i put a set of i think it was early r6 headers on my hybrid and had to cut the front out of my race fairing to get it to line up to the brackets and mounting points , those look the dogs by the way , what you using for a link pipe . i had to make one , what a c**t to get a bend in the pipe without creasing it . ended up filling the pipe with sand and a big pipe bender Lol
