starting problem
ROCK
- Bike owned: fisher price race division
starting problem
Hi all just bought a tri arm the other day, the bike rode home fine, and for a few days, went to start it after being out for a short run and it would nt start, so I charged the batterie and the bike started straight off, so I took the bike to work today the bike started and rode great, and started for the ride home but when riding home I pulled up at the lights and it cut out and I had to bump it to get it going, I ve had a few 400 s now and in the past the rectifier has played up, has any one got any ideas how to help with the problem?
cheers
stu
cheers
stu
- bluebird400
- Bike owned: Honda CBR400 NC23 HRC
Re: starting problem
Sometimes the reg/rec gets overheated, which increases the resistance so that if it cuts out or you try to start it when it is hot, it won't go. I suspect that rather than benefitting from a charged battery, what actually made the difference was having the chance for the reg/rec to cool down.
Have a look at the reg/rec for signs of overheating. Also check the pickups - do that a number of times over the course of a couple of hours. I had a problem with the reg/rec AND the pickups but only found one after I'd solved the other as it was being "masked".
Central Line in rush hour or the A40 by bike? - well Duh!
ROCK
Thought it might be the rectifier, where abouts are the pick ups and how would you check them, sorry I am a bit thick when it comes to electrics
- bluebird400
ok, easiest way to explain this is gonna be with a manual. Have you got a Haynes?
