SOME ADVICE PLEASE!!
Chris 91UK
- Bike owned: 91 UK Spec RWB NC30
also im going to upgrade the rear. im 6ft 1 so want to raise aswell. if i purchase a maxton/nitron etc do i still need to purchase a jackup kit (RO jobby!)
cheers guys
Re: SOME ADVICE PLEASE!!
I belive you need the yokes aswell, i have some ducati showas for sale, racetech internals and springs setup for a 12-13 stone rider, Zero use since rebuilt. £150
As for the rear end no i dont think you do need the jack up kit if fitting a posh shock. If you have a NC30 then i think fitting NC35 linkages etc raises the rear a little
Chris 91UK
jeez that was quick!!
aha ducati showas! do you have the yokes? sounds like a good price mate. what sort of nick are they in, you have any pics?
im 11stone (soaking wet,fully clothed!!) would they be ok or slight adjustment?
thinking of a maxton rear end
pgm
i could well have a maxton shock for sale from the end of next week its coming out of my nc35.
Sorry dont have the yokes but riley, the guy that does the fitting kits for these is bound to have a set which i think need to be modified if memory serves me right.
Pics
Very good condtion apart from the red tops have faded a little. 11 stone should be fine as theres loads of adjustment. I have a maxton on my NC, theres no height adjustment but im on tip toes moving it about, im only 5.8 ish tho
Pics
fastdruid
It does, it also has the advantage of replacing the bush with a bearing making it much easier to tighten up the suspension (its mildly tricky to ensure the shock is in the correct position so you don't preload the bush before you tighten the lower shock bolt).Drunkn Munky wrote:As for the rear end no i dont think you do need the jack up kit if fitting a posh shock. If you have a NC30 then i think fitting NC35 linkages etc raises the rear a little
Druid
Chris 91UK
Nice one munky but the links not working for me
thanks for that druid,im pretty sure im going to go maxton or nitron though,got a bonus coming to me thats there 4 the taking!
Fixednc30 newbee wrote:Nice one munky but the links not working for me![]()
Chris 91UK
25th of this month any good for you? (theyre SEXY
PS any directions you can point me in to get the rest of the bits i need to get these on th NC will be much appreciated.
im going to pm riley now. which exact model are they off?
Ta
Ta
The 25th is good for me.
There off a 748 model, 40mm caliper spacing not 65mm. remember that when shopping for calipers
Your need,
Yokes
Calipers
Discs
Wheel
Clipons
Your need,
Yokes
Calipers
Discs
Wheel
Clipons
