Reg/Rec advice
bradders
Reg/Rec advice
So my reg/rec went the other day, looking at replacments I'm stuck on which one to use; Genuine, pattern or Rick Oliver's Heavy Duty one, has anyone got any pros/cons on these, is there much more beef on Rick Olivers? Cheeers :)
Re: Reg/Rec advice
I've never had any dramas with used 2003-4 yam R6 units.
Have fitted 3 now and have picked them all up for next to nothing (tight ar$e!). I don't trust honda units at all.
Before (genuine honda - binned it!):
http://i19.photobucket.com/albums/b171/ ... CN2732.jpg" onclick="window.open(this.href);return false;
After (R6):
http://i19.photobucket.com/albums/b171/ ... CN2731.jpg" onclick="window.open(this.href);return false;
After (R6):
pgm
Re: Reg/Rec advice
hi stickshift, is the r6 unit a direct fit for the nc 35?
mart
- Bike owned: sp1, sv650, nc30
Re: Reg/Rec advice
would have thought not, but would be an easy chop and solder the nc30 connectors on or try to take the spade connectors out of the connector blocks and put the nc30 blocks on
- banoffee
Re: Reg/Rec advice
picked up a pattern one from ebay - working a treat. mind you, I did replace the alternator and battery for new ones at the same time too
Re: Reg/Rec advice
I have a 05 R6 Reg/Rec on mine.. you have to either get the appropraite plug (and change it) or just use some insulated spades
pgm
Re: Reg/Rec advice
ok cheers guys.
Re: Reg/Rec advice
If you go for the R6 reg/rec it has 5 pins
[-]____[-]
[-]_[-]_[-]
if you look at it like that, top left is Red (+) top right is green (-)
The bottom 3 are the yellows (any order)
[-]____[-]
[-]_[-]_[-]
bradders
Re: Reg/Rec advice
Cheers man, i'm guessing the nc's are a 5pin aswell, i'll have a look into it tomorrow,not sure if i wanna start chopping the harness up or not.
Biscuits
- Bike owned: '88 NC24
- Location: approaching the apex, carrying too much speed...
Re: Reg/Rec advice
Yay! Yet another post from me because something else has stuck/broken/vanished/exploded...
My reg/rec has shuffled off it's mortal coil (just like you said Neo
and I need a replacement pronto. I can get my hands on a 1999 R6 unit but will it do the job?
I guess it won't be a straight swap job, I have the lump hammer and cable ties at the ready (joke) (honest).
Formerly RacingSlug. Felt like a change and it came down to either Biscuits, Ben10 (possible copyright issues) or NinjaSmokeWarrior. The wife suggested TwatMan.
