fuel tap positions
- ibby4585
- Bike owned: SP's
fuel tap positions
hi, could someone clarify fuel tap positions on a nc30 please?? (please dont call me a thick twat under your breath!!)
tomski
Re: fuel tap positions
From memory;
Theres a marker on the fairing just above the tap, labelled fuel.
As long as your tap is standard, just line up the positions (ON,RES,OFF) labelled on the tap to the marker on the fairing.
Simples
Simples
- paul nc 24
- Bike owned: 2000 R1
twelve o'clock = on
three o'clock = off
six oclock = res
(thick twat)
hope you didn't hear that
three o'clock = off
six oclock = res
(thick twat)
- ibby4585
- Bike owned: SP's
very simples!! many thanks. i did hear that by the way!!
- Sligeach
the tap has a long lever and a shorter lever, the shorter one pointed toward 12oclock is normal fule flow, the longer one pointed toward 12oclock is on reserve
- ibby4585
- Bike owned: SP's
jesus thats 3 different answers now!! thought it was meant to be simples
- paul nc 24
sorry ibbypaul nc 24 wrote:twelve o'clock = on
three o'clock = off
six oclock = res![]()
(thick twat)hope you didn't hear that
who's the thick twat now me
and you dont have to keep it under your breath!
i had been reading nc24 tap problems before reading your post
neurosyndrome
Isn't it a bit stupid???Sligeach wrote:the tap has a long lever and a shorter lever, the shorter one pointed toward 12oclock is normal fule flow, the longer one pointed toward 12oclock is on reserve
Because if you need to put the tap on "res" when you're riding, you have to pass through "off", no?
Isn't it a proble at 100 mph on a track?
It sould be but the carbs have a fuel supply in them so a small disruption in fuel form the tank is on worries.neurosyndrome wrote:Isn't it a bit stupid???Sligeach wrote:the tap has a long lever and a shorter lever, the shorter one pointed toward 12oclock is normal fule flow, the longer one pointed toward 12oclock is on reserve
try turning your fuel off next time you are out - it takes a good few seconds to start to pass out...
neurosyndrome
To sum up, and also to add some pictures
Can someone confirm the following pictures, please? :
Res?
Off?
On?
If you're blind, here are the links
Res : http://img340.imageshack.us/img340/6044/resq.jpg" onclick="window.open(this.href);return false;
Off : http://img517.imageshack.us/img517/5413/offgr.jpg" onclick="window.open(this.href);return false;
On : http://img517.imageshack.us/img517/6338/14749763.jpg" onclick="window.open(this.href);return false;
Cheers,
Res?
Off?
On?
Cheers,
