NC35 fuel tap issue
Smitizen
NC35 fuel tap issue
Would the NC30 tap kits be the same as the NC35's? Mine has a slight leak also and needs replacing.
Here's my mechs report of the service just done after my bike broke down -
Remove carbys, strip & clean; reset float heights X2; cylinders filling sump with fuel; balance carbys & reset mixtures; NOTES: * Fuel tap needs replacing * * RUN ONLY ON STANDARD UNLEADED* Cheers, Chris
And how rooted (or not) is my bike if this is happenning?
Cheers.
Cheers.
Re: NC35 fuel tap issue
Good thing it has been fixed though as it wouldn't have lasted long. It shouldn't have done any permanent damage though.
Pretty sure nc30 and 35's use the same fuel tap.
Smitizen
How sure are you that they do? I need to get myself one ASAP!Stickshift wrote:Good thing it has been fixed though as it wouldn't have lasted long. It shouldn't have done any permanent damage though.
