nc30 gearing problems
				zedvfr
I keep having problems with my NC30 popping into neutral when moving from 1st to 2nd gear. It causes a few problems on track days as it happens when you really could do without it!
Is this a common nc30 fault? and how can I sort it?
- yayoboy
Re: nc30 gearing problems
maybe see if the linkage needs adjusting, its a long shot but it will only take a minute to check  :D
				zedvfr
cheers, will take a look. Maybe needs a complete new chain I would think by now too!
				randallbass
check your chain and sprockets, and chan tension.
also give all your linkages on your gear selector a good clean and make shore the adaptor on the engine selector shaft and your selector rod has a 90degree angle or thereabouts so you have the best leverage :)
cheers Tim
cheers Tim
				Simon_Ed
i have a similar prob on my 35, i've adjusted the gear lever down a little just so the change is more positive, failing that i'm gonna try a race shift pattern
						- CRM
Worn dogs, another symptom is jumping out of first at very high RPM when say thrashed from the lights.
If its not selecting second properly under load and you have ruled out chain and sprockets then try after hooking second, back off the throttle and on again, that i bet locks it into gear and it doesnt jump after that, if it does then the box is past its best
				zedvfr
Thanks very much guys. Will give it all a good going over - not got any track days for a couple of weeks now so I have time to give him a good going over! :)
