brake problems(paranoia..maybe!!!!)
- Bike owned: zx9r c1
im getting what feels like a judder from the front brakes when i use them.....more so at higher speeds in excess of 60mph!!!!!
i had the brakes off the bike and put other calipers on which i got from ebay,bled them and they work fine....nice and firm but now the judder!!!!!!!
any ideas??????
cheers folks!!!!
:D :D :D
any ideas??????
cheers folks!!!!
:D :D :D
- georgenc30
- Bike owned: vfr7506x nc30 nsr250sp
Re: brake problems(paranoia..maybe!!!!)
What calipers have you put on the nc maybe they have a slightly different offset check to see that all your disc bolts are tight. Are the pads thicker than standard nc ones??? just some ideas for you.
warped discs,wheel bearings? a shudder like a vibration in the bars or a noise maybe headstock bearins Russ
- Sligeach
i had judder in my front end, was advised on four things
1. fork bushes
2. loose or fooked head race bearings
3. wheel bearing
4. mudgard loose!!
turned out ot be my head race lock nut working loose, give it a quick torque up and it was sorted
1. fork bushes
3. wheel bearing
4. mudgard loose!!
Warped discs i reckon.
I get a judder when i break aswell i might add, doesn't bother me though she goes and stops just fine. :)
me 3, im worried incase its the whel bearings or something expensive, im ordering new o rings from rick oliver 2moro and gettin my calipers rebuilt soon and when i get this done ill get the suspension set up proper and all bolts well tightened. If this eradicate the judder i guess it could only be
warped discs
wheel bearings
something equally expensive,
warped discs
wheel bearings
its original nissin 4 pot calipers and the pads are the correct size.........all bolts are nice and tight and i believe the bearings to be hunky dory!!!!!i think the spindle is nice and straight but i had a hell of a bother getting it back through when i had the wheel off the other day.
the wheel is ok,no damage buckled or anything like that.....theres numerous things it could be but they all appear to be fine,its looking like paranoia and in a way i hope it is........coz that would mean there is nothing up...lol!!!!!!!
:D :D
:D :D
