doing my head in.
- Bike owned: too many to list
doing my head in.
any body know of a good cheap bike mechanic in the leeds area that may come to me ? no van for transport. got a spark got. tried easy start no joy ! with tank off and a clear tube full of fuel when turning it over it doesnt pull the fuel in??? this is with air box top off. had carbs off n jets out once. w.t.f. !! ready for burning it. !!! or any ideas ?
Re: doing my head in.
Airlock ? maybe
scrap that just gone in garage for a fag n fired it up n it run !!!!!!!!!!!!!!! but only on the back cylinders ? how easy are the plugs to get out to check at the front ?
Fiddley as the rads etc are in the way but its do-able.Dodgy Roj wrote:scrap that just gone in garage for a fag n fired it up n it run !!!!!!!!!!!!!!! but only on the back cylinders ? how easy are the plugs to get out to check at the front ?
- Bike owned: '30
Drain the rads from the water pump on the left hand side, then loosen the upper rad right hand hose, and undo the rad fasteners, then drop them and you can access the front plugs.. Just dont over tighten them once theyre cleaned and put back in
